Retrofit Interior Footwell Lights
ScottishA4B9
Has anybody installed any?
I’ve seen some from this company:
We supply interior OEM lighting kits for your A3 8V: www.rocketwires.co.uk
They look good but red only. I like the ones on eBay but they are cigarette lighter or USB plug in types but I would prefer a hard wired variant. I like how the eBay versions have a remote and various colours to choose from.
maxpayne
Just received my kit from AliExpress. Only $34 and as you can see all genuine parts. Will follow up when I’ve had a chance to retrofit.
Dubjam
Moderator
Staff member
Moderator
Lol, I highly doubt they genuine parts at all, just Chinese fakeys stamped with genuine part numbers and logos.
Still, they will do the job, LED's don't really command enough voltage to cause a fire etc. In the with past the Aliexpress specials, the LED's dimmed over time and occasionally flickered, but I hear they have gotten somewhat better these days.
Mark csl
Procarkits Handsfree Autowatch Ghost and more
i installed this set all working but not as bright as i would have expected.
But i havent seen the factory lights.
Its an easy install and it worked right away i coded the mmi but i find i have them off when driving.
maxpayne
Or that haha. I’d imagine the OE lights are made in China too. I bought footwell and puddle lights for my 8P from AliExpress too and they were spot on and I don’t have any reason to doubt these too.
The 8P ones were a bit dim and I just updated the LEDs using ones supplied by @t8ups.
ScottishA4B9
Do they change colour or are they just one colour?
RobinA3
Site Sponsor
Site Sponsor
With 8V footwell lighting set up the front LED is very small and the light output isn't great, there are a couple of options though, stick with the standard small light and replace the LED bulb with an aftermarket one from EMTuning which also gives you the option of a red bulb or a lot of my 8V customers opt to fit the 8P set up which is a bigger light, gives off a better spread of light but you will need to cut a hole for the light to fit into on the plastic trims but this is straight forward to do and can't be seen once all fitted. The benefits of this apart from the better spread of light is its a cheaper set up, you can have red and more importantly the rear footwell light output will be the same as the front because the rears use the larger sized light.
As for whether the aliexpress kits are genuine or not I can't confirm however all I can confirm that a single 8V front footwell light costs me £14 (trade price).
ScottishA4B9
I’ve spoken to you about your kits mate and looks like I will be ordering some tomorrow.
ScottishA4B9
I’ve used Robins kit and can recommend, all terminals at the correct length.
Just ordered the interior footwell lighting kit and the door and puddle lights kit from him! Can’t wait to get them and get them fitted!
ScottishA4B9
maxpayne
I have a set of retrofit kit for sale here:
