Friday,06,November,2015,19:50:39:40635
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WAUKFGFF0F113XXXX License Plate:
Mileage: 3243km-2015mi Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 55 5F
6C A5
VIN: WAUKFGFF0F113XXXX Mileage: 3243km-2015miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-CNTC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0006
Revision: --H13---
Coding: 0A1D00324466000F3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
ROD: EV_ECM20TFS0205G0906259A_AU37.rod
VCID: 2C57BA6647958C5ED1-8078
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 K HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4515
Revision: 05853104 Serial number: TFK01504051057
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1E3360AE01296ECE4F-804A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 60805000003091
Coding: 13FF6A9234230A740178030381C629C8562C5080C08194B4184150588208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 4999E3F2E827B976CA-801C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0365010490
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A7B8C3EBDC122EE53-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000620697
Coding: 03000014010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 3365A11A9AABD3A690-8066
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 AB HW: 5Q0 937 085 AB
Component: BCM MQBAB MNA H18 0137
Serial number: 01011510000879
Coding: 04151D46C04106FD41C04004511007A00800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 79F95332F847E9F61A-802C
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150413 042 0585
Serial number: 150416172542
Coding: 0A47F7
Slave 2:
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 23884850
Coding: 07006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 04 02 2015 00000303
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000032249687
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST0008NYWP00000
Coding: 101F00
1 Fault Found:
534549 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 10
Mileage: 3243 km
Date: 2015.11.06
Time: 15:45:54
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39391509700601
Coding: 0070151011
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_AU37.rod
VCID: 428BF4DED5116A2E0B-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 23021503273588
Coding: 01241701FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387F963683CD30FEA5-806C
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 009 0825
Serial number: 003GCR01TSYL
Coding: 9DCCFCC0000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 479DE5CAFE334F06DC-8012
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34178311B16041571539
Coding: 333135
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34178312B17041540136
Coding: 333135
Seat occupant detection; front passenger side:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y150001AYK803
Coding: 303230
Crash sensor for side airbag; driver side:
Subsystem 4 - Part No SW: ----------- HW: 480 001 304 15
Component: SideSensor_Df 001 0887
Serial number: 3570000000022D901414
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 5 - Part No SW: ----------- HW: 480 001 304 15
Component: SideSensor_Pf 001 0887
Serial number: 35800000000A34A01416
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 904 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002A51A87862A2E8
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 904 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002B31A87861C12$
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 8 - Part No SW: ----------- HW: 480 402 502 15
Component: FrontSensor_D 001 6149
Serial number: 3550002AF1993FB293AQ
Coding: 2D2D2D
Crash sensor for front airbag; front passenger side:
Subsystem 9 - Part No SW: ----------- HW: 480 402 502 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B11993FB363EG
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 ED HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 15041504220165
Coding: E818
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 000F3ED69B9DB83E5D-8054
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 971 G HW: 8V0 920 971 G
Component: KOMBI H02 4292
Coding: 0BC518196F88D7050280E8001800000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 4189FBD2D017713612-8014
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 16041510800439
Coding: 0101000830085A005B00021C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti.rod
VCID: 72EB641EA5319AAE5B-8026
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 27 03 2015 C0094125
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7082
Serial number: HA1-00017.03.15
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4683E8CEF939560E27-8012
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000092647005
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3467A2069FA5D49E89-8060
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0363707495
Coding: 030211
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_AU37.rod
Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 230315BCL20716
Coding: 005D1F205C00048000000003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 9102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 4385F1DACA0B632600-8016
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 310315BCU1225A
Coding: 005D17205E00048000000003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: --------------
Coding: 012A000123200400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3F8DFD2AA6E307C664-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 038 B HW: 8V0 035 038 B
Component: MU-H-LNS-US H43 0394
Serial number: A302D0FB012316
Coding: 017301020000000021220002041A00102F000125010001047E
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 ST HW: -----------
Component: NAR 2015/2016 --- 0044
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY202Y9Z
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000027021500030513
Door Electronics Rear Left:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 3006
3 Faults Found:
6697 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 50
Mileage: 716 km
Date: 2015.07.16
Time: 13:17:22
6667 - Optical Data Bus for Information Electronics 1
U10CA 00 [008] - Intermittent Disruption
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 50
Mileage: 660 km
Date: 2015.07.11
Time: 12:34:42
6937 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 50
Mileage: 2237 km
Date: 2015.09.21
Time: 11:46:11
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAAU914.rod
VCID: 306FAE166BBDE8BEED-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 10000330712
Coding: 0100020000010303000500010100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3B75893AB2FB1BE648-806E
1 Fault Found:
2359296 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 10
Mileage: 3243 km
Date: 2015.11.06
Time: 15:43:16
End-------------------------(Elapsed Time: 04:47)--------------------------
