So I bought an A3 1.8T Quattro at the weekend, it needed a few bits doing to it. It had 4 new tyres fitted and came with 2 new from lower arms and ball joints, a new rear shock front drop link a CV boot and a rack boot. I paid £500 for it so hopefully it was worth it.
One of the arms had been attempted to be fitted by the previous owner who clearly didn’t know what they were doing. The paint works not the best by any chance but it’s not too bad condition overall.
I’ll up load a few photos as I go. I used to use Tiny pic as it was a free hosting site and I’ve used it for probably over 10 years but now it’s closed If anyone has any suggestions on a free image hosting site I would be greatful and can add plenty more photos as I go.
So far I’ve listed some jobs I need to do to it:
Oil level sensor repair/replace wiring
OSR shock advice NS aswell?
Clean engine and Transfer box re-seal?
Breather pipes rocker cover.
Resecure intercooler
Lower arms and subframe back on
OSF rack boot
NSF indicator bulb and rubber seal(possible change lights?)
Polish up paint work?
Tighten drivers door hinge
When I say put the subframe back on, I refer to my earlier comment about the previous owner not knowing what they were doing.
They had started to put the drivers lower arm on and clearly struggled, they put the arm on with the old ball joint as they only got so far with loosening before it started spinning( I then found out they cut halfway through the taper shaft) and I later found out that they had put the arm bush bolts in the wrong way round.
I thought that the front bush bolt nut had started spinning or they had cross threaded it but it turns out they just used the correct bolt on the rear bush which is longer!! I was going to cut the subframe open to re-weld the nut and the close it back up and weld back but thankfully I don’t need to do that now! Just need to put the subframe back on.
Hopefully I can get some advice along the way as my daily is an A6 C6 which I’ve had next to no problems running at 217k currently and had since 150k
OSF rack boot
