Wednesday,09,March,2016,19:03:55:17189
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
www.Ross-Tech.com
VIN: WAUZZZ8P6CA084565 License Plate:
Mileage: 158760km-98648mi Repair Order:
Chassis Type: 8P (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 37 42 44 46 47 4C 52 55
56 61 62 72 77
VIN: WAUZZZ8P6CA084565 Mileage: 158760km-98648miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 AL HW: 03L 906 018 AG
Component: R4 2,0L EDC H26 7764
Revision: 41H26--- Serial number: AUX7Z0KNFN30GX
Coding: 0019003A042601080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM20TDI01103L906018AL 003003
ROD: EV_ECM20TDI01103L906018AJ.rod
VCID: 74DF9F47DFF80A9E6A-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 14426012092A00FE281006EA901E00523F0400
VCID: 7BCDB47BFAA645E62B-802E
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 237
Mileage: 158516 km
Time Indication: 0
Date: 2016.03.01
Time: 05:59:18
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 53504
Count: 0
Count: 1021
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 C HW: 8U0 820 043 C
Component: E87 Klimavoll 0040
Revision: 00H03000 Serial number: 8U0820043C
Shop #: WSC 00000 000 00000
VCID: 31515653A86A7FB6C1-8064
1 Fault Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 208
Mileage: 158701 km
Time Indication: 0
Date: 2016.03.08
Time: 06:21:05
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 110 0667
Revision: AJ110667
Coding: 46000A2FA8051AC0207040E00100895C42FE2BAA206CF16AE400CF840041
Shop #: WSC 06314 123 12345
VCID: 3FB5006BAE3E99C647-806A
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
1 Fault Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 248
Mileage: 158701 km
Time Indication: 0
Date: 2016.03.08
Time: 06:13:15
Freeze Frame:
Term 15 Off
Voltage: 12.50 V
OFF
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0140
Revision: 11001001 Serial number: 12501130400501
Coding: 100203
VCID: 49A11EB3E0FA2776E9-801C
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H09 0250
Revision: -------- Serial number: 003JU004UN5S
Coding: 30314238303830303035554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 529339DF05AC64AE98-8006
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000E24529CY
Crash sensor for side airbag; front passenger side:
Serial number: 3582DRB40000E24931AU
Crash sensor for side airbag; rear; driver side:
Serial number: 35128RB400006632C105
Crash sensor for side airbag; rear; passenger side:
Serial number: 35228RB40000661D586L
Crash sensor for front airbag; driver side:
Serial number: 35547RB400006745631C
Crash sensor for front airbag; front passenger side:
Serial number: 35647RB400006745603C
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004042
VCID: 46BB158F31E4C80E04-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 N HW: 8P0 920 932 N
Component: KOMBIINSTR. VDO H02 0150
Revision: D0H02002 Serial number: 224NK002039068
Coding: 0277028
Shop #: WSC 38178 000 104857
VCID: 3FB5006B6E3E99C647-806A
Address 18: Aux. Heat Labels: None
Part No: 8P0 265 081 F
Component: Heizgeraet H08 0060
Revision: 00H08000 Serial number: 09011596000000
Coding: 0001012
VCID: 345F5F4757784A9EAA-8060
1 Fault Found:
00664 - Fuel gauge
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 243
Mileage: 158598 km
Time Indication: 0
Date: 2016.03.04
Time: 06:06:07
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 241011F2000913
Coding: 352102
VCID: 3B4D747BBA2685E66B-806E
1 Fault Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 248
Mileage: 158701 km
Time Indication: 0
Date: 2016.03.08
Time: 06:13:14
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
Component: Haldex 4Motion 3018
Coding: 0000005
VCID: 45B912830CE2C3160D-8010
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H02002 Serial number: AUX7Z0KNFN30GX
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7LD220688
Coding: 0225755
Shop #: WSC 00493 128 187288
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0131252
VCID: 49A11EB320FA2776E9-801C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 233 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158124360928
VCID: 365B654F4104588E94-8062
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 Q HW: 8P0 959 802 Q
Coding: 0131252
VCID: 4AA321BF25FC2C6EE0-801E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0011
Serial number: 111107-0002-032
Coding: 1163A51010022100
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: 42B3099FD5CCF42E28-8016
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0225755
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F30F185A
VCID: 71D19653A8EA3FB681-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0131216
Shop #: WSC 06314 000 1012544
VCID: 42B3099F1DCCF42E28-8016
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0131216
VCID: 43BD0C9B02D6FD2623-8016
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005459414
Coding: 0011411
VCID: 355962435C0253969D-8060
End-------------------------(Elapsed Time: 02:19)--------------------------
