Hi all,
Hope you can help me! I have been having a problem lately with the central locking on my audi a4 B8 year 2008. The problem I have is that when I lock the car, it locks fine, but when I open the rear passenger side door does not open from the outside, you have to crawl into the car and open it from the inside using the handle, it also does this with the passenger side door also, although if you press the lock button twice on the fob and then the unlock button the passenger front will unlock, it is an intermittent problem with the front and started as an intermittent one with the back door, however the back door now nearly always needs to be opened from the inside, unless you keep repetitively pressing open/close on the fob and eventually might get it!. I have done a VAG scan and got the following:
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 022 JM HW: 03L 906 022 B
Component: R4 2,0L EDC H01 3173
Revision: 11H01---
Coding: 0104002C18072018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TDI03L906022JM A01005
ROD: EV_ECM20TDI03L906022JM.rod
VCID: 79F2681249B1
3 Faults Found:
4985 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 00 [047] - Open or Short to Ground
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
4986 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault
P0673 00 [047] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
4987 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
P0674 00 [047] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9E3544U88
Coding: 2F0D080002002600010000
VCID: 31629032D141
1 Fault Found:
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 236
Mileage: 123575 km
Time Indication: 0
Date: 2014.12.24
Time: 15:44:37
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G08729833A
Coding: 000303
VCID: 4688D3EE48CF
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 26
Reset counter: 235
Mileage: 121919 km
Time Indication: 0
Date: 2014.11.03
Time: 19:53:00
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H80 0146
Revision: 00002001 Serial number: 0113216735
Coding: 011B062200390440002001
VCID: 30649536DA4B
Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
2 Faults Found:
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 121356 km
Time Indication: 0
Date: 2014.10.30
Time: 09:36:15
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 38
Reset counter: 239
Mileage: 121356 km
Time Indication: 0
Date: 2014.10.30
Time: 10:19:57
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000100199220
Coding: 010002204001210001
VCID: 4084C5F66AEB
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 30
Reset counter: 239
Mileage: 121379 km
Time Indication: 0
Date: 2014.10.30
Time: 19:58:35
Would really appreciate some help with this! especially since I have actually sold this car and it is due to be collected and I have told the buyer I will get this fixed! Sods law for these things to happen at the most inconvenient times!
Your help is much appreciated!
Chris
Revision: 11H01---
VCID: 79F2681249B1
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 121379 km
Date: 2014.10.31
Time: 15:04:11
VCID: 31629032D141
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 236
Mileage: 123575 km
Time Indication: 0
Date: 2014.12.24
Time: 15:44:37
Coding: 000303
VCID: 4688D3EE48CF
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 26
Reset counter: 235
Mileage: 121919 km
Time Indication: 0
Date: 2014.11.03
Time: 19:53:00
VCID: 30649536DA4B
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 121356 km
Time Indication: 0
Date: 2014.10.30
Time: 09:36:15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 38
Reset counter: 239
Mileage: 121356 km
Time Indication: 0
Date: 2014.10.30
Time: 10:19:57
VCID: 4084C5F66AEB
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 30
Reset counter: 239
Mileage: 121379 km
Time Indication: 0
Date: 2014.10.30
Time: 19:58:35
Chris
