  2. Dismiss Notice
pcv delete
hydro s3 Jul 21, 2017
  1. hydro s3
    hydro s3 S3 amk
    1,241
    359
    I have a 2001 s3 amk. Im wanting to do the pcv delete and add a catch can and vent to atmosphere. I looked at the stickies but because of photo bucket there is no pictures of what i need to do which would really help. Could some one that has did this done and still have pictures help out. Thanks
  2. Avatar
    snack-media
    Advertisement
  3. SamHendry
    SamHendry Active Member
    827
    165
    43
    You have two pvc outlets on the 1.8t. One on the top of rocker cover and one top of oil filter housing. Both outlets are the same diameter.
    Personally I didn't bother with a can, I just vent to atmosphere directly but basically it's just a case of getting a couple meters of hose and a selection of 90 45 bends and t-pieces then plumbing all together.
    If you use a can then I would imagine there would lots of jiggery pokery fitting everything in but direct to atmos is really straight forward and maintenance free.
    andrew_wright likes this.
  4. basil brush
    basil brush Active Member
    620
    228
    43
    And a massive danger to motorcyclists !!!!
  5. Tj 0785
    Tj 0785 Well-Known Member Bronze Supporter Silver Supporter VCDS Map User
    3,600
    1,071
  6. SamHendry
    827
    165
    43
    He thinks venting crankcase oil vapour onto the road is a danger to motorcyclists.
  7. andrew_wright
    andrew_wright Active Member
    124
    29
    Have you seen how much comes out? 6 months and none. Whatever is making "sludge" from the breather to create a drip would mean you're engine is in very bad health. No oil or any other **** come out the pipe my end. And yes I fitted a can....waste of money if you're engine is in good nick.
    Sent from my Nexus 6 using Tapatalk
    SamHendry likes this.
  8. hydro s3
    hydro s3 S3 amk
    1,241
    359
    Is the reason for fitting one not so that you cut down on the chance of cracked or split pipes and also to have a health engine because the **** is not going back into engine? I will be getting a rebuild done so i thought adding this will help keep it healthy.
  9. andrew_wright
    124
    29
    What's going back into the intake is minimal at best on a clean running engine.
    Like I said if you got loads of stuff coming out of them pipes you have a bigger problem than just vapour.
  10. SHUk
    SHUk Once Bitten Forever Smitten =]
    357
    27
    Can I run a pipe from the oil filter breather to the hockey puck on the inlet and vent the crank case breather...
  11. Erikn89nl
    Erikn89nl Well-Known Member
    951
    388
    Simplest PCV delete is a pipe from oil filter breather, pipe from crank case breather, T-junction, straight to hockeypuck.
  12. Avatar
    snack-media
    Advertisement
  13. S3Powerxz
    S3Powerxz Member
    108
    I made it as the guy above said, but i made it to vent to atmosphere, not in the hockey puck/tip. What's the point to pcv delete when it will go in the tip after all?
    I have a question about venting into atmosphrere. From the T i run 0.5m long pipe, but when the car is not moving on idle there is coming a lot smoke from the pipe after 2-3 min idling. No problem when the car is moving.
    Is this normal?
