Hi! I have a 2006 Audi A3 2.0T. Just recently I developed an odd situation.
Once the car warms up, I get a "Oil Pressure" warning on the dash. A few things I've noticed though is that the light only comes up while moving and in gear while the RPMs are BELOW 2k. Above 2k it shuts off. Stopped and at idle it doesn't turn on either. The motor never sounds any different.
I've changed the PCV, Oil pressure sensor, oil and filter.
I did use an Audi filter and Mobil 1 5w40 Full Synthetic.
No codes on dash. But I have stopped driving it once the light appeared. Other than testing it out after the changed parts.
One last thing to note, I tried pulling the oil cap off while motor was running and it had great suction. Almost seemed as though the car started to idle higher, but still idling smooth. But didn't leave the cap off to see.
The car is completely stock with 90,000 miles. I was going to drop the oil pan and check for sludge, but I didn't think the 2.0 had the sludge issue that the 1.8's did. Thanks in advance for any help or ideas on what to check next.
