Oil between gearbox and engine?
Ronny_nordstrom
Hey. From where can this oil come from? it seems to be dripping out of the check holes from the underside where u can see your flywheel. Did a clucth service with a buddy and replaced the rear main seal and sealed it with gasket also. When looking into the hole the main seal i dry and flywheel. So no idea where this small oil can come from? Hard to explane, will try and get a photo next time i am under the car.
B5NUT
Well-Known Member
It's either coming from the gearbox output shaft seal or the crank seal. I know you said you replaced it but it could be a bad seal or it's been damaged during fitment. Either way it a gearbox out job to check what is going on.
Ronny_nordstrom
i checked inside the holes and didnt see any oil around the rear main seal there was coming oil before i did a main seal and clutch work. still comming
Skickat från min CLT-L29 via Tapatalk
B5NUT
Well-Known Member
Only other option is to check behind the engine, see if there is oil coming form the HG or rocker cover and it seeping between the gearbox housing & the engine, but I would suspect you would also see it on the edges of the gearbox housing. If that is fine then there are only 2 places oil is coming from.
Ronny_nordstrom
valce over gasket is changed. How hard is it to swap HC gasket on there 1.8t?
B5NUT
Well-Known Member
If you have changed a cambelt before then you should have no problem with the HG, however that would be a very last resort in looking for the oil leak as it should be obvious if the HG has a fault. I'm more favour the valve cover they are known to leak oil, more so in the corners were they say to put a bit of silicone sealant.
Did you check the seal on the gearbox. The seals on my gearbox were leaking so replace the drive shaft seals & input shaft seal.
Ronny_nordstrom
but the oil seems to come from the top down. where is the gearbox seal? dumb question but..
I have done 3 timeing belts and balance shaft delete on B7 tfsi engines. and cam replacements
B5NUT
Well-Known Member
Seal is behind the pressure plate. Sounds like you should easily replace a HG.
Ronny_nordstrom
when we dropped down the gearbox, this side was dirty and oily. didn't change that seal. think i need to check with a camera inside if its leaking. did the clutch with a friend 1 month ago.
