do you have obd eleven \?Yes for the meet, although, will hold back on tweaks for now.
Not tried yet. 1st one on my list would be to turn off, Start/Stop.Can you activate few options ?
on ali express is that connector , once member claim its workingNot tried yet. 1st one on my list would be to turn off, Start/Stop.
I am sure, you will be the first to advise on how. Hope you had a good break.Not possible via coding now.
Interesting, plug&play.. may try it.on ali express is that connector , once member claim its working
16.57£ |For Audi A3 8y 2021 2020 Sportback Limousine Sedan Engine Start-stop Canceller Switch Default Closer System Plug Cable - Starter Parts - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Yes there is info from.another member all.works.fineInteresting, plug&play.. may try it.
Same seller ? i want order one so.dont have to put it.off all the timeI've got one of the start stop devices, took all of about 2 minutes to install and has been working well for the last 2 weeks
A9 Soundaktor
What's the setting std? I'm sure I read 100% on here somewhere? mine was set to 80%
Is this able to be altered using VCDS, sorry I'm still learning what's what.A9 Soundaktor
Yes, but doesnt come up under installed modules, once searched for it appears, just search A9, you can alter the % 'noise'Is this able to be altered using VCDS, sorry I'm still learning what's what.
It was from Ali express but from a different seller.Same seller ? i want order one so.dont have to put it.off all the time
Must be a tiny microchip emulating a key push after 3 secs after power-up, or similar power on delay pulse.I had one on my 8V.
Quite a bit smaller and was easier to get back in the hole.
I've just done this today, might be in my head but the sound seems cleaner/more defined, almosy like it was semi distorted before, really happy with it, cheers.Yes, but doesnt come up under installed modules, once searched for it appears, just search A9, you can alter the % 'noise'
Good sound to be honest and very like it should sound, the one on my Golf R sounded like a cross between and RS3 and a scooby so I turned it off
I should've been fitting the ASR today but the missus didn't hear the door yesterday, so Monday. Sounds promising though.I’ve found 50% with ASR I can hear more external exhaust sound.
Had the neighbour ask what happened to the car to make it noticeably louder yesterday
Hello all
I asked everywhere but still no luck and really need help
This RS runway display is locked on Japan version so even if you press the RS button only normal display
shows up and even on MMI when you chose display only 2 choices can be selected and is shown
Anybody can try to tell me where I can find the RS runway display coding area so I can try to unlock?
Or second solution provide me a copy of the OBD back up so I can compare with mine and define the area where it is locked?
All help appreciated
Hello all
oooh Thanks you.So basically nothing I can do here except Audi Japan decide to update it?It’ll be locked by firmware. Nothing that OBD will be able to change.
it;s nothing specialYeah for some odd reason some markets receive different MMI layouts and features, where I’m from we also don’t get the runaway layout.
I don’t really recommend, 90% of the codings don’t work for the 8Y and even ones they say they do (for example disabling the headlight washer doesn’t work and plenty more), if you want to code get vcds, but you might need it for unlocking some things to access them using vcds ( @8YARWY is the guru so ask him for more detailed explanation I haven’t done it haha)Just noticed ODBeleven Pro pack on special deal until tomorrow on their website plus £21.72 shipping. Seems a good deal?
I recently bought OBD11 pro and works fine (8v s3)
- added the audible alarm blip
- removed fake exhaust (soundaktor) sound to 0%
- increased throttle pedal (however can’t really notice a difference)
- increased comfort turn signal from 3 to 5
- mirror dip
the above in itself is worth the money for me but each to their own
When driving it won’t let you type, safety feature I believe, you have to use voice, can’t recall if you can drawer the letters though. Agree it’s annoying as your passenger can type!Guys how can i remove the mmi message when you start car? Privacy statement message. The do not show again is greyed out.
Also how can i input address into sat nav keyboard when moving? As a passenger its annoying as its greyed out.
Yeh you have to draw it which is a pain. Bigger unsafe feature. Can it not be sorted via obd11 and the message at beginning?When driving it won’t let you type, safety feature I believe, you have to use voice, can’t recall if you can drawer the letters though. Agree it’s annoying as your passenger can type!
Yes, PITA that the passenger cant use the type function, voice activation is not bad thoughWhen driving it won’t let you type, safety feature I believe, you have to use voice, can’t recall if you can drawer the letters though. Agree it’s annoying as your passenger can type!
Agree the voice activation is pretty good to be fairYes, PITA that the passenger cant use the type function, voice activation is not bad though
