Novice User Help Req Please
Dinotqs
I’m about to do a xenon conversion using Kufatec adaptors and one line of the instructions says:
Coding Value Byte 10: x1xxxxxx (set bit 6 onto 1)
This is what I see in Byte 10:
Any ideas?
Others may correct me but as far as I remember with this sort of coding:
The last Bit in a line of code is zero and is always the farthest on the right. So the instructions say "set bit 6 to 1".
Hence you count Bit 6 being the seventh from right to left: 01000000
So go into that box and change the zero to a 1.
I would always advise that you have a full copy of the module saved before you do this so you can revert if all goes wrong. You should make a Controller Map or Admap first in case.
Reactions: Dinotqs
Thanks for taking the time to reply, it will help a lot!
When I tried to change the info in the binary box it wouldn’t let me but I wasn’t trying that hard as had 8% charge on the laptop and a faulty charging port! Do you know if it can be edited?
