Just bought a 2002 Audi A3 tdi Quattro, which I really like... BUT
I think that the DMF has failed as the heavy rattle from the clutch / flywheel / gearbox area is worrying to say the least. New clutch and DMF ordered and on it's way. Just hope it's not the box itself, no noticeable bearing rumble, grinding, whining or selection issues... Looks like there is a small oil leak which may be from the box or transfer, are there any seals I should get as a precaution?
On a separate note there are a number of central locking issues that I have discovered while trying to find out why the remotes won't sync.
The story so far...
What I have deduced...
So can anyone tell me the colours of the wires that run to the boot key lock in order from bottom to top or plug positions 1-3 I guess the middle one will be the brown one (as mine is) as I suspect there may have been some tampering somewhere. Why they would ever be transposed is anyones guess but there may be a theme here... A wiring diagram would be great if anyone has one to hand.
Thanks in advance, all comments appreciated...
The story so far...
- The radio was in safe mode with no code supplied
- Can only lock and unlock the car from the drivers door
- The boot only operates from the key, the touch buttons do not function
- When the boot lock is turned to the open position the car doors lock and vice versa
- The display shows correct open / closed status of both doors and boot
- The radio works fine now I have reconnected the CAN lines at the radio connector -> so must be the original
- The central locking pump has been swapped for an earlier non radio one -> that sorts out the remotes! Correct replacement will be ordered
- I have had the lock out and both the switches, all functioning as expected and meter out OK
