Multifunction display!?
Chops77
Is it possible to retrofit multifunction display to a vehicle which doesnt have it already?
What i actually mean is, is it just simply a case of changing the wiper stalk to one that operates the display?
Or would my dash diplay not be capable of using it as it doesnt already have the correct stalk?!
You just need to change wiper stalk and do some coding in vcds it's a 15min job ;)
Reactions: Chops77
dont forget the washer level sensor grounding when you change the stalk
not always as the part of the loom from washer to column is not always there depending on model and spec, i think audi thought they were saving money. there should be a guide somewhere around
Did that, changed the washer stalk and fitted a washer level sensor. Bought the sensor from amazon for like 6$. The sensor fits behind the driver side fender so some work is required. It took me an hour to install and another hour to figure out how to get the wire into the dash. The other wire just ground it any where.
