Lowering Springs
Timi8888
Hi all,
I’m looking to get my car lowered and want to see if anyone has pics of theirs lowered on standard 18inch wheels?
Also if you’re running Eibach or H&R and what the ride quality is like?
I have read the H&R Supersports are the lowest with a 30/35mm drop, but maybe too much bounce. The Eibach pro kit drops 20mm and is not too far from standard spring ride quality. Not sure if 20mm drop is enough so wanted to see some pics please!
Thanks.
Timi8888
Bump.
Any one got reviews on ride comfort of ANY lowering spring?
I just want a spring as low as possible without having the bouncy wavey feeling when going at higher speeds.
SevenW
I will be changing my suspension again in the very near future.
I was on OE stuff on 17's, then went to 18's with a 26.5 " ground to fender gap.
Changed to Solo-Werks coilovers then changed to 19's. Gnd to fender is now 25.5" Approx a finger gap.
The coilovers are really comfy and at their price point real good value, but coil slap is bugging me at slow speeds, I installed them with new mounting gear when new, I also installed Tein spring silencers and the setup was silent as, but now 1 year later I am getting pings, clicks and squeaks, which can be cured by jacking up the car and just adjusting the springs in the pans, but the noises return after a few starts.
Anyway......I have now purchased a Bilstein / Eibach B12 Sportline setup which will hopefully get put on nextweek or so.
I have eibach springs on mine ride is maybe 10% stuffer at most. None of my passengers have noticed but it’s corners much better
First one is oem
Second just after fitting
Third on aftermarket 18
Forth on Audi 19s
SevenW
-Ju-
Well-Known Member
This is mine on H&R springs with 10mm spacers all round
18's
19's
The ride imo is better than oem, although I do have magride.
I also have a set of Eibach pro's in the garage that I never fitted
Timi8888
18's
19's
Are these H&R sports or super sports?
I have heard a lot of mixed reviews on these. Some say the ride is very wallowy and bouncy at high speeds?
-Ju-
Well-Known Member
Sorry, I've no idea on the version, afaik these were the only ones listed and they drop the car about 30mm, or 35mm in my case as I have magride.
I've not noticed any issues with the ride but like I say I have magride.
I've had H&R's on all my cars, the only one I had an issue with was my previous 8P S3 as I thought it settled a little too low and gave me issues with speed bumps. No issue on the 8V as it sits higher at the front
Timi8888
How much you selling the Eibach Sportlines for?
Testing out an S3 with VWR springs on Sunday. Interested to see how low it make sure the car sit and if it has the wallowy feel to it.
-Ju-
Well-Known Member
You can have them for £80 plus the postage if your not anywhere near me
Timi8888
What did you think of the vwr springs?
Very impressed with the VWR springs.
His first set VWR replaced free of charge as the front springs seemed as if they stayed under tension when compressed. Every now and then he would hear a twang as if the spring suddenly lost its compression.
But the replaced set he is very happy with. Cars sits nice and low. Stiffer but doesn’t bounce over small potholes and speedbumps like the standard springs do. Also no wallowy feel when going over dips in the road at fast speeds.
-Ju-
Well-Known Member
I'll check the model number when I get home, Its not as much as the sportline
Timi8888
You said you’re selling sportlines, but then said the springs don’t go as low as sportlines? Lol
Timi8888
I think you'll find I said pro's!
Oh I see, two people selling Eibach springs lol, one sport lines and one pro kit.
Pro kit lowers by 10-15mm and the sport lines are 25-30mm I think.
SkiddyRebel
That’s great! I might be going down this route, just hope they’re not too low for 19s!
Timi8888
It looks spot on believe me!
AndyKnight
It's a couple of mm higher now as my replacement springs were a new spec from vwr but the difference is negligible.
Timi8888
Didn’t know you was on this forum mate!
scott8v
hey guys, iv got a 2014 184 quattro s line, i think it had SE suspension from factory, fitted eibach sportline springs, sits nice, handles really well and not too harsh a ride when in comfort mode.
however, when the front springs where fitted, the top strut mount was refitted but the spring wasn't under tension, and the strut had to be refitted to the car, lined up correctly and hub jacked up to get tension on spring. is this normal? mot pass or fail.
fitted lowering springs in the past but never has the spring not been under tension. thanks
AndyKnight
That's not normal. @DJAlix had the similar issue with his lowering springs and yes it is an mot fail if your springs are not under tension with no weight on the wheels.
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
hmmmmm my mot is in 6 weeks, did DJAlix get a resolution to his problem?
I removed my mss kits track front springs and installed Mss street fronts :)
