looking for A3 8p 09-12 S-line Bi-xenon / Led DRL passenger headlight unit.
Hardy1.8TFSIA3
kent
my DRL has died so need to replace the whole hedlight unit.
picture attahed of what i'm after, ideally loooking for good used condition or even brand new if the price is right.
Good luck.
Everyone sells them as a full front end or as a pair or with damaged brackets.
I bought a replacement from TPS a couple
Of years ago. Was about £400ish
It's not just the headlight, you'll need to have it adjusted diagnostically as it will throw an error until calibrated.
Whereabouts are you?
Really? Mine was fine
You really do need to calibrate properly.
likewise, mine was fine. Beam was set with a headlight setter as per normal procedure.
Depo headlights are slightly cheaper, that’s what I bought and have no complaints.
Slightly less iirc, unless buying modules too, but not cheap & adaptives are more.
Euro car parts have the adaptive xenon for £850 each, with one of the bigger discount codes you could halve that.
