Hi;
I have Audi A3 8L 1.9 TDI; year 2001.
Recently I had issues with right main light (it's Xenon 35W with HID ballast, I got car with those).
I thought it may be the bulb, so I bought bulb 35W, installed it. It worked 30 - 40 seconds, started flickering for few seconds then turned off.
I found that Capacitor 4700 microfarads, 35V may help in this if connected to specific wires, checked tutorial, connected it exactly as described. Did not help.
Then I did bypass the HID and put ordinary halogen bulb there to the headlight. Yes, different color, different strength,anyway it is workaround till solution. That was two weeks ago.
Yesterday, even the halogen stopped working. Works few minutes, then not, then works again. Looks like some bad contact in wiring.
I opened the headlight, checked connections, checked main bulb connection, it started to work, then was off again. Also, I reseated small position white light, it went off as well. Not broken, it is not getting the power.
Now three lights/ bulbs not working: main light bulb, small position bulb, red back position bulb.
Still working: long light bulb, parking orange bulb, fog light bulb. All mentioned bulbs are at the right side of the car.
Have to mention that I checked fuses, did reseat all of them. Fuse 18 is related for those lights, it is checked, OK.
The issue seems to wiring related. Have to ask if someone has some suggestion for this, what to do?
Thank you.
Thank you.
