It doesn't sound like it is activated.
Are you in dynamic, traction control off, ....... ?
Strange - daft question S-Tronic ?
Should build boost and rev to 4,000rpm giving you 4 seconds in which to take your foot off the brake. Only ever done the one myself !
Yep all modes are activated , dynamic & traction control off
You sure your gear box is in S? Mine used to do that when I put it in dynamic would not put he gear box into sport and would not activate launch
Easy was to tell is the car should not be pushing forward at all...it should be like Regina in neutral.
Nah gearbox is in S mode too
My S3 doesn't show any boost being built when launch control is activated? However holds full boost fine when driving? Anyone know the cause of this? Thanks
Strange indeed..maybe post a video or pic of what it does?
Also what happens when you let the brake go?
When you let off brake does it bog down?
Different car but mine does not work if hill hold assist is activated.
What effect does it have? From what you say I'm understanding it as it brings the interval forwards a bit each time you do it? Sounds strange, or have I misunderstood?Who knew the amount you launch it effects the inspection service intervals? It counts how many times you do it. The audi salesman was most confused when i asked to plug mine in and have a look before i bought it
The variable servicing looks at loads of stuff, including lanuches. More will mean an earlier inspection.What effect does it have? From what you say I'm understanding it as it brings the interval forwards a bit each time you do it? Sounds strange, or have I misunderstood?
More info on 8V launch control here
http://www.audi-sport.net/xf/threads/launch-control-limit-fact-or-fiction.245027/
@Rob2k68 - 8V LC counter here (with VCDS)
http://www.audi-sport.net/xf/threads/8v-vcds-mods.206515/page-23#post-2466229
The boost is only torque demand anyway, it isn't showing boost so don't worry.
Ignore the bog at the start, the boost is too high in first gear for the torque limiter of the DSG
No it isn't mapped, it is running a jb4 tuning box but the only that changes launch control is extra boostHi thanks for that video, I take it your car hasn't been remapped? As mine does the same as yours
@Rob2k68 - Having no 8V A3/S3 & no VCDS I was unable to check this, so thanks for confirming your findings Rob@Bristle Hound using the latest version of VCDS there are no measuring blocks with either launch or control in the string present in my 02 Auto Trans module .....
To the main question here someone will ask... using Carista can you reset the count?@Rob2k68 - Having no 8V A3/S3 & no VCDS I was unable to check this, so thanks for confirming your findings Rob
I use the Carista app on my B8.5 S4 & with the current raft of updates on it it now has a Launch Control counter
I would imagine, if it already hasn't, that Carista may include this in their future updates for the 8V's
http://www.audi-sport.net/xf/thread...iable-for-the-8v-a3-s3-pfl-fl-covered.303522/
@azibux1 - No. Not on the Carista app for my car. Its just a counterTo the main question here someone will ask... using Carista can you reset the count?
@Rob2k68 - Will be interesting to see if Carista add the LC in the futureThere is no launch counter in Carista either which makes me firmly believe that the DQ250 box does not have one unlike the DL501 (S4/5) which has a rumoured limit of 200.
