Key Fob
hubbo1
The wife left the key fob on a hot hob!
I got a new key fob and luckily the circuit board was intact so swapped to the new fob and changed the blade but unfortunately the glass transponder didn't fair so well.
can I buy a new transponder? and then code the key to the car?
2.0 Tdi 2005
2.0 Tdi 2005
The Key number is 8E0 837 220E, does anyone know which transponder it takes?
Give the wife a bill for the key-------------- on second thoughts don't do that as you'll get billed for other things, learnt that lesson a long time ago.
No idea on which transponder you need. Just pop into a Remote Car key specialist near you, they are popping up all over the place these days.
Reactions: DrStrange
Ive done quite a lot of research for this over the years..
If the circuit board is fine..indeed its a straight swap to an empty shell Key Fob.
The transponder chip I believe is called an ID48 and is near enough cheap as chips to buy on Ebay. Fiver circa.
Its needs to be programmed obviously. There is a way to do this if you have one perfectly functioning key (spare) by placing 1 key in ignition and 1 in drivers door. Not sure which way around.
Otherwise, you need it to be reprogrammed by a specialist as Soot1 said.
A link to help you on Transponder Chips below.
http://transpondery.com/transponder_catalog/audi_transponder_catalog.html
Hope it goes well for you mate...do let us (or me) know what you do, as i have an empty Key Fob which needs all this done as my motor only came with one key.
Press & hold the unlock button, insert key in ignition still holding the unlock button, hold unlock in the on position for two seconds, turn key to off, remove key & release button.
thanks will let you know how it goes
487
949
717
714
