Judder when accelerating any thoughts?
Buxton2901
Hi Guys, some help please if you can.
Recently noticed some vibration/judder on the motorway.
Most noticeable when slowing down and then accelerating, engine really judders.
When accelerating from a stop and up through the gears is fine.
Also when downshifting through the gearbox there is no judder at all.
Car is A6 BiTDI with 8 speed ZF box
Has anyone experienced anything similar?
I am going to scan the car for codes using carista later today to see if any codes flagged up
Paul
Rhyso
Any particular revs?
i had something similar a coule of years back in my 3.0 (single turbo). It would happen at 1500rpm up in 5th /6th / 7th
turned out to be a split pipe which goes into the inlet. It’s the pipe below the coolant tank at the bottom of this picture
EDIT - just re-read your post......mine only happened during acceleration. Sorry!!
Buxton2901
Aye mine is only doing it under acceleration. Low revs as in when slowing then accelerate again..
Will check hoses also
Buxton2901
Just been out again in it at lunch time.
much worse at low rpm in high gears.
keep it in 6th or 7th and accelerate from 1200rpm the whole engines shakes until it gets to about 1800-2000rpm and stops from then
Rhyso
Pretty much the same symptoms as mine!
Fairly sure i it was the pipe at fault but i also had other work done at the time; had all the injector sleeves and washers replaced and both rocker cover gaskets as they were leaking
Buxton2901
Aye well I've had one rocker cover gasket changed recently as it was leaking.
Fingers crossed it's just a hose
Will update this post if I find out the cause
Buxton2901
Update. Been under the bonnet and found a pipe going into the turbo inlet was unclipped. No idea why. May have been left off when they did the rocker cover gasket.
What is the hose for anyone?
Also there was oil and smoke Coming from the hole. Normal?
Unfortunately I did also find oil coming one of the injector seals so needs a visit to the garage to get that sorted.
Buxton2901
Also picture of fuel/oil leaking from the middle injector on the driver side bank
Rhyso
I’d get all the injector seals and washers etc done mate
What’s the mileage on the car?
this was the state of my injectors at 100k.....
M
y mechanic said there was hardly anything left of the seals.......
Buxton2901
81k mate. It's booked in with an Audi specialist on Monday so we'll see what happens.
Buxton2901
How much did that cost to get done mate? Did they just clean them all up and stick em back in?
Rhyso
just under £500 all in
half was labour; half was parts BUT i had both rocker cover gaskets and the pipe replaced all at the same time. The pipe was about £80 and I’m sure the gaskets were like £25 each or something??
my garage charges £60 an hour labour to give you an idea. He cleaned them up and refitted the injectors :)
Buxton2901
So my car is in with an injection specialist today who have identified a compression leak from the injector.
suggested taking the 3 injectors out from that bank and testing them and then installing my seals and o rings etc.
I have told them to do all 6 at a cost of £330. obviously if one or more of the injectors are ****** then the price will rocket
Does that sound like a reasonably price?
Rhyso
Labour rates vary depending where you live. As per my previous post my garage charged me approx £250 for the labour.
£250 were parts of which £80 was for the pipe and approx £50 was for both rocker cover gaskets so that would be approx £120 for the seals and washers for the injectors which sounds about right so £330 sounds decent to me mate :)
Buxton2901
Garage just been on the phone and injector 5 has no idle and 3 out of the other 5 are passing fuel back past the seal....
He did say all 6 failed on coding which I believe just means they are worn and slightly out of spec but he said they will be fine for now.
580 quid all in including new injector and the testing, new seals etc
Rhyso
Expensive day out for you mate :(
From the research I did it seems common for the injector seals to go on these engines from 75k onwards......another service item to add to the list!!
Rhyso
How does the car drive now mate?? I assume you've had it back??
Derv_guzzler
oh ****....some times, when I drive off and gently press the accelerator, I have what appears to be hesitation/judder. Feels like incorrect fuel-air mixture. Started happening after the fuel filter was replaced so thought that the fuel line had not been bled properly and air was in the High-pressure part, but now I am not so sure...
Turbo john
Hy guys , got same issue with mine .a6 c7 2.0 tdi ,190bhp . Judder at low revs 1500-1700, in 5th,6th,7th gear when try to accelerate slowly is fine ,once i try slightly harder before gearbox jumps to lower gear ,the whole car judders.soon as revs are up to 2000rpm ,no prob at all . JUST to confirm i have changed the gearbox oil and filters ,and is the same . No fault codes at all . I have replaced n/s driveshaft ,and engine mount ,and same thing - no change.
Turbo john
HELLO MATE , HAVE YOU SORTED OUT WITH YOUR CAR ?? I GOT SAME ISSUE ,WITH MY A6 2.0 TDI STRONIC ,2016 190.
Turbo john
Paul
Hello mate , i got same issue with my a6 2016 . Have you sorted with yours . I have changed loads , and still same issue. I m just annoyed. Cheers . John
Buxton2901
Cost me 300 quid to have all 6 injectors out and tested. New seals and o rings etc. 200 to replace the faulty one
Sent from my SM-G980F using Tapatalk
