Hi, I upgraded from a symphony 2 to a rnse . I plugged all the ISO leads (3) I had into the quadlock but why have I got this one spare it's from the quadlock but I got nothing to plug into it that I can see ? I have a parrot kit fitted too,
Si
They go to the BT module, you need to trace the wires back to the plug on the RNS-E and there should be a pin-out diagram on the top of the RNS-E. Depending on where you got your wiring harness you will need the wiring diagram from elsawin to know where each cable connects to.
