Is this ok for an oil change?
setdet
trafford68
Was not sure how to put this in the title, but,
My A4 is a TDI2.0 Ultra Sport 150BHP
80,000 miles when bought
Now has 80,102m on clock and engine oil change due.
I do 4K miles a year max.
Using an electric pump to syphon out the oil (via the dipstick tube).
I believe the capacity is 4.7L; I sucked out about 4.4L. I then added about 4.5L of the Castrol. The system said "Oil Level OK" and was at Max. The engine probably had at most 300ml of used oil in - I guess.
All done with engine up to temp.
Next change in 365 days.
Question,
Does leaving that amount of used oil in the sump do any harm with the change for the mileage of the car and miles I do? Has it not been "diluted" by the new oil to some degree?
Even taking the sump plug out to drain there’s always some residual oil in the system so wouldn’t be an issue.
95% of your oil is fresh so the little residual is unlikely to go bad causing problem.
Reactions: mister.c. and setdet
Thank you kind gentleman for your insight and help. Another great forum result
Reactions: mister.c. and pelhamsdetailing
