Hi, i have the 2012 A3 convertible and on Friday i noticed the soft top symbol flashing to say there was a fault ,i tried to take the top down and i got the message soft top cannot operate. I then noticed that the rear right window was not going all the way down ,however after switching engine off and opening and closing the door it all was working again ... I then scanned the car with vcds and got the fault codes relating to the rear right module...This morning i got the same flashing symbol and issue with rear right window, however after trying the buttons a few times and opening and closing of the door it works, basically it seems a intermittent problem. I have read that the door hinge loom can cause issues ..The module and motor are smooth and quiet and i would have a look at that but at the moment can't work out how to get rear door card off,i have looked at some of the fittings on a used one on ebay and it looks like there is only 3 fasteners and what looks like two prongs that stick out and slide in to something, I don't see any bolt holes if anyone can help on the door card removal that would at least let me look at the module and see what colour wires are going to it ..Any help on any of the above would be appreciated .Thanks
Sunday,24,January,2021,12:29:19:04136
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
www.Ross-Tech.com
VIN: TRUZZZ8P1B1004211 License Plate: V20OWL
Mileage: 181350km-112685mi Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 61 62 72 77
VIN: TRUZZZ8P1B1004211 Mileage: 181350km-112685miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 1110
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 M HW: 03L 906 023 L
Component: 1,6l R4 CR td H23 9973
Revision: --H23--- Serial number: AUX7Z0J8FN70SN
Coding: 00114034030501080000
Shop #: WSC 01236 785 00200
ASAM Dataset: EV_ECM16TDI02103L906023M 003014
ROD: EV_ECM16TDI02103L997557Q.rod
VCID: 303911D20AA2510BC33-8064
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 13422012092200FEC80D04E5901A0091380800
Shop #: WSC 01236 758 00200
VCID: 76B5E7CAA8C63F3B59F-8022
Address 08: Auto HVAC Labels: None
Part No SW: 8P0 820 047 E HW: 8P0 820 047 E
Component: J255 Klima Man H08 0060
Revision: 00H08004 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 323D1BDA082E631BB57-8066
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 F HW: 8P0 907 063 F
Component: BCM PQ35 B 107 0615
Revision: 00107 AF
Coding: 46000A3FAA13F140207060E00500004C53325CAA0000C522E4008F000055
VCID: 372B2ACEEF4C8633829-8062
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No: 8P7 951 177
Component: DWA-Sensor H0 H03 0050
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 94
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 20:46:43
Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93631028726473
Coding: 000001
VCID: 42DD4B1AB48ED39B257-8016
Address 15: Airbags Labels: 8P7-959-655.clb
Part No SW: 8P7 959 655 HW: 8P7 959 655
Component: SR Airbag 9.43 H01 0020
Revision: 93H01002 Serial number: 003BS0015N0S
Coding: 0021330
VCID: 0655970AD4262FBB49F-8052
Subsystem 1 - Serial number: 6332DRB40CEB8CB3B
Subsystem 2 - Serial number: 6342DRB40CED95262
Subsystem 3 - Serial number: 63747RB405E00EE6-
Subsystem 4 - Serial number: 63847RB405E012FAV
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0003011
VCID: 46D5570A94A6EFBB09F-8012
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H04 0100
1 Fault Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 H HW: 8P0 920 982 H
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2248J003006189
Coding: 0260418
Shop #: WSC 12345 123 12345
VCID: 3E253FEACC76B77B41F-806A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H33 5304
Revision: H33 Serial number: 071010F1001261
Coding: E9A07F2600060204009101
VCID: 313F14D60D285803CCD-8064
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 20:46:44
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 35
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 10:49:57
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01003 Serial number: AUX7Z0J8FN70SN
Address 26: Auto Roof Labels: Redir Fail!
Part No: 8P7 959 255 B
Component: VSG AUDI A3 H14 0130
VCID: 44D14D02A29ADDAB17B-8010
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 50
Mileage: 179488 km
Time Indication: 0
Date: 2020.12.26
Time: 21:31:34
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 G HW: 8P7 959 801 G
Component: Tuer-SG H04 0103
Coding: 0131764
2 Faults Found:
02071 - Local Databus
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 233 3001
Revision: 00H17000
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P7 959 802 F HW: 8P7 959 802 F
Coding: 0017044
1 Fault Found:
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 8P0 907 534 HW: 1K0 907 951
Component: Batt.regelung H33 5304
Coding: 030B085A
VCID: 74B1DDC2BEBA2D2B67B-8020
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005650408099
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 8P7 959 811 B HW: 8P7 959 811 B
Component: Tuer-SG H01 0054
Coding: 0131216
VCID: 42DD4B1AB88ED39B257-8016
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005237980
Coding: 0001202
VCID: 74B1DDC2B2BA2D2B67B-8020
2 Faults Found:
02503 - Output Wire to Radio
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 35
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 10:50:02
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 12:07:04
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.2V)-----------
Code:
www.Ross-Tech.com
Revision: 00H31001
Revision: 00107 AF
Coding: 00DD13
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 94
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 20:46:43
Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
ON
Term 50 Off
OFF
OFF
Coding: 000001
Coding: 0021330
Coding: 0003011
1 Fault Found:
01304 - Radio
Coding: 0260418
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 96
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 20:46:44
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 35
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 10:49:57
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 41
Reset counter: 50
Mileage: 179488 km
Time Indication: 0
Date: 2020.12.26
Time: 21:31:34
Coding: 0131764
2 Faults Found:
Revision: 00H17000
Coding: 0017044
1 Fault Found:
Address 56: Radio
Cannot be reached
Coding: 030B085A
Coding: 0131216
Cannot be reached
Coding: 0001202
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 35
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 10:50:02
01304 - Radio
Freeze Frame:
Fault Priority: 6
Reset counter: 189
Mileage: 178046 km
Time Indication: 0
Date: 2020.12.04
Time: 12:07:04
Code:
