Interior handle ambient light retrofit
Piggi89
Hello, can anyone help. I am away to order all wiring kits to retrofit footwell lights, puddle/warning lights, glove box light and interior handle led lights however I have a problem. I need to order the new genuine interior handles from Audi which have the light fitted but tps can't help as I need to know the part number or know of a car reg which has them already fitted so they can find the part. That way. Does anyone know the part numbers for the handles, car is an a4 2013 saloon. Any help would be much appreciated.
I have searched the internet but can't find part numbers on any forums.
Murray
I have a 2011 with the extended lighting pack and lights in the door handles mate if you want to start a conversation with me ill happily give you my reg number or chassis code. Am sure the B8 and B8.5 handles are the same?
Reactions: Sandra
Hello, I have a 2012 a4 avant s-line. I have upgraded the interior with:
Door warning /puddle and glovebox :
http://www.audi-sport.net/xf/thread...fit-and-puddle-light-information.81670/page-2
Ebay Parts (for the glovebox part # are in tuto above):
http://m.ebay.ie/itm/8Pcs-Door-Pane...A5-A6-C7-A7-A8-Q3-Q5-/321505359875?nav=SEARCH
Footwell:
http://www.vwaudiforum.co.uk/forum/showthread.php/155034-Retrofit-footwell-lights-front-rear
Ebay parts:
http://m.ebay.ie/itm/Set-OEM-Interi...A7-A8-Q3-Q5-Q7-TT-VW-/151583390411?nav=SEARCH
Door handles illuminations:
Drill 5mm hole on top of door handle were oem diffuser would be located. Sand paper the led to give it a mat effect, this will diffuse the light better. then glue it in. Connect it to controler using the pin out found in the door warning/puddle tuto above.
Parts:
4x 5mm 12 volts bright red LED's from ebay (pack of 10 around €10)
2x repair wire 000979009E from Audi (€14 )
I havent done the door ambiante lighting as my door modules dont support it, but here is a tuto:
http://www.audienthusiasts.com/Project_DoorLighting2.html
10
