No cause for concern there.After 500 Miles after a service of driving in my 1.8tfsi, it's consumed this much, is this normal?
Sure made my night. I will correct for you now. xHaha were was predictive text on that one!!
If i remember correctly the sump takes around about 5 litres total, the on screen gauge shows 1 litre and you get a warning once that litre has gone to chuck a top up bottle in there
That's quite cool if it does display to people that don't check it regularly .You might even find that that level has changed the next time you check it if ambient conditions are different.
Question:- the past two times that I have dragged my 2011 S4 out for its exercises, during each run, I've been handed out that "oil level okay" display for a few seconds. Over the previous 3.5 years that I've owned that car, I have never seen that being issued and if I wanted to use the built in oil level monitor, I had to manually request an oil level check. I do have a dip stick fitted though for peace of mind. Is this something that Audi has programmed in for lazy people that never check their oil level, ie if you don't request a level check regularly, it will give you one?
+1 on this ^I use a dipstick on mine. That way, I can check the condition of the oil as well as the level.
Mine does it now and again, I believe there is a sensor of some sort in the engine bay that will flash up the oil level when you open your bonnet. I'm guessing this takes a knock now and again so flashes up the level
+1 as well, though I'm not checking the condition of the oil as I don't run enough miles and never use that car for short journeys - what a waste of a car?I use a dipstick on mine. That way, I can check the condition of the oil as well as the level.
You have just made me think a bit more about this, since maybe last 18 months my S4 when left in the garage, is left with the bonnet open and connected to a CTEK battery maintenance unit, so yes, every time I take it out for a drive, I have just closed the bonnet! Never thought about that before, as well as the fact that I've got a CTEK unit connected to it, the other reason that the bonnet stays open is because once I had a field mouse attack the foam round the rear most end of the bonnet area, so I've got a "rodent annoyer" plugged into the wall beside the car and so I leave the bonnet open to maximise its potential!
Edit:- the nasty but unfortunate field mouse family fell fowl of my baited traps, only ever had this happen once over the period of 20+years in this house, even had an attack on the Ibiza parked outside the garage, similar closed foam seals, but not on wife's August 2015 VW Polo 1.2TSI 110PS parked in garage beside the S4 !?!
I've had some sort of rodent attack the foam on mine as well, little ********!
