sebhar70
Fitted B5 S4 brakes with spacers on my audi TT RS alloys, just wondering does anyone know what wheels (OEM/Reps) they will fit under without spacers?
You wont get wheel wobble of increased bearing wear with a spacer if you stick to a reasonable size , as all your doing is altering the ET of the wheel slightly ,
only thing is you need a 12mm hubcentric front and 13mm rear so the hubcentric part of the spacer clears the original spiggot of the hubs on the B6
or as i am doing soon removing the hub and machining the original hub spiggot a couple of mm so 10mm hubcentrics go straight on
you can run 5mm spacers with longer studs if you like as this will still allow the wheel to sit on the original spiggot of the car then you would only have to take a very small amount off the calliper .
Mercedes Brabus (reps) fit without any problem's . I had b5 s4 brakes on my b6 and had the same problem, Brabus wheel's 19"x8.5" was the size of the wheel no spacing required . The only other wheel that will fit is the Ronal 18" x 8" as found on the s-line model's the replica of this wheel will NOT fIt.
Thanks for info do like Ronal 18" and was considering going for these but in reps ain't got £800-£1000 spare for OEM.
