  2. Dismiss Notice
Haldex Gen5 oil change and gauze clean.
Fatbloke Sep 21, 2018
  1. Lehn
    Lehn The van man
    1,129
    1,332
    So, I changed my haldex oil and cleaned the filter again after 20.000km. The reason for changing the oil was mainly because it has been 20.000km since last time i did but I did also experience the car holding 1st gear longer than usual WOT before changing to 2nd. Of course this could be due to my JB4 but the fact is that after changing the oil it made a huge difference and the gearshift is now snappy changing from 1st to 2nd WOT. I talked to George from Burger Motorsport before the oil change and he told me that the slow change from 1st to 2nd normally is due to lack of traction and the car would hold the rpm until the speed catches up and then shift.
    My conclusion:
    • The first oil change is way more important than the second (the filter was almost clean this time with no clutch residue on it)
    • There were a small amount of black spots in the bottom of the oil pan but not the same amount as first time I changed the oil (See my quoted post)
    • I didn't feel a difference between OEM oil and Bilstein (I put Bilstein on again)
    • Fresh oil equals more traction
    • 15-20.000km interval is recommended, especially if tuned
    Some pictures from the oil change:
    Nice and clear oil
    Almost clean filter
    Before cleaning
    Clean housing (also before cleaning)
    w.h.i.p.p.e.t, alpesh26 and N.J.H like this.
  2. Avatar
    snack-media
    Advertisement
  3. alpesh26
    alpesh26 Registered User
    739
    179
    43
    How did you guys get the electrical connector off the pump? I remember leaving it connected first time I did this as I didn't want to snap anything.
    I bought the Bilstein oil this time, its in exactly the same bottle as the OEM stuff...
  4. N.J.H
    N.J.H Registered User
    21
    19
    You don't need to disconnect the pump you can wiggle it out carefully and leave it connected.
    alpesh26 and Lehn like this.
  5. Fatbloke
    Fatbloke Registered User
    414
    135
    43
  6. alpesh26
    739
    179
    43
  7. Damo S
    Damo S Registered User
    732
    325
    That Febi stuff is what I used for mine too. Btw I have the haldex oil changed and filter cleaned every service now (10k miles).
    Fatbloke and alpesh26 like this.
  8. alpesh26
    739
    179
    43
    For how much it is and how long it takes its silly not to
    Damo S and Fatbloke like this.
  9. Fatbloke
    414
    135
    43
    Is it fine just reversing up onto ramps to do the oil change or do you need to get the front jacked up too so its level?
  10. Lehn
    Lehn The van man
    1,129
    1,332
    I would recommend to make the car as level as possible because the drain hole is pointing forward, the fill hole if pointing to the left and the haldex pump is pointing backward.
    I did just what you suggest and it worked great:
  11. Fatbloke
    414
    135
    43
    Where did you put the axle stands?
  12. Avatar
    snack-media
    Advertisement
  13. Lehn
    Lehn The van man
    1,129
    1,332
    I just jack the car up on one of the big bolts on the subframe and then put the stands where you would normally jack the car if you just need to change a wheel.
    Below is on a Golf but same principle of where to put the jack and the stand:
    Below shows where you can jack the car on the subframe (here with the stands instead of the jack of course):
    w.h.i.p.p.e.t and Fatbloke like this.
  14. The_Ironist
    The_Ironist Registered User
    449
    254
    Just had mine done on 3rd year service at 24k miles. Not as bad as I expected tbh.
    Before:
    After:
  15. selleym
    selleym Registered User
    145
    138
    43
    Need to be doing more 4 wheel drifting :racer: haha
  16. Damo S
    732
    325
    Agreed, probably the cleanest I've seen. Your pump is most likely fine as a result :)
  17. RC-S3 8v
    RC-S3 8v Registered User
    12
    Just had my Haldex oil and filter cleaned at 57k. Was changed at 38k by Audi but obviously don’t clean filter so wanted it done.
    Was a lot of swarf! Defo one to do.
  18. christy1999
    christy1999 Registered User
    10
    Have you had a look at the whee bearing?
