I'm wondering if anyone has experience of these two products. I pick my Glacier White car up on
Saturday and have everything I need to prep the paintwork. The thing I'm missing is the sealant. I've decided I'm going to give a ceramic coating a try (will probably regret it I'm sure) but I'm not certain which one to choose.
The cheapest and safest would appear to be Cquartz UK as you can apply reload after an hour to hopefully guard against possible water spots if the unexpected happens while it's curing. It's £50 for 50ml which will do the recommended 2 coats. I have read it can be more difficult to apply though.
Gtechniq stuff seems to be in at the moment. £85 for CSL + EXO V3 + panel wipe and should do one coat of each. It seems it may be easier to apply, but it's a pig to remove if done badly.
I'm looking for which one is the easiest to apply and so which I'm less likely to make a mess of. Which should last longer or give the best finish.
With it being white I'm nervous of not getting all the residue off as it's hard to see and then it could be too late. I'm also a little wary of the longer cure time for CSL.
