Evenin' all
3 weeks into 8V FL S3 ownership (first new-ish car in a long time) and the honeymoon period is over
Audi seem to nanny us a bit and so I picked up an OBDEleven to sort out the bits that either aren't available to adjust in the MMI or just not available generally. Like adjusting your headlights (wtf?)
Here's a list of the changes I made to mine.
What changes have you guys made to yours?
The OBDEleven unit was worth it for this alone. It's daft that you need a diagnostic tool just to do a simple headlight adjustment. Easy money at Audi Servicing I guess.
Note: When I made some changes I noticed that some MMI settings had returned to their defaults, so you might have to run through the car settings in the MMI to confirm your customisations. e.g. my Auto-Folding mirrors were "on", but had reset to "off" and my Rain Sensor I switch "off" was back "on" again.
- "Auto leveling" Headlight adjustment. Mine were straight up dangerous. 25ft illumination if that. I have no idea how it passed it's MOT with its lights like that.
Code:
Engine running + bonnet wide open
OBD: Control Units | Basic Settings | Basic headlamp setting | Activate
Once activated, use a screwdriver to adjust the headlights to the correct level
OBD: Deactivate
Engine off, lights off.
Engine on and lights on. Confirm they "auto Level" to your new setting correctly
- Exhaust flap deactivation (permanently open). I paid for 4 tailpipes, I wanna hear them dammit
Code:
Engine running + bonnet open, select Dynamic Driving Mode and rev over 3000rpm to make sure exhaust flaps are open
Engine off
Ignition on (not engine)
OBD: Apps | Exhaust Flap Deactivation | Value: OFF
"Off" freezes it in it's current position. Do the above with a different driving mode if you want the flaps closed all the time
- Comfort Turn signal. Default 3 flashes. I tried 5, but that was even more distracting, so turned it down as low as it'll go (2).
Code:
Ignition or engine on.
OBD: Apps | Comfort Turn Signal | Value: 2-5
- In cabin engine noises (aka Soundaktor or Structure Borne Sound) Turned from 100% to 0%. It wasn't bad, just more unnecessary noise.
Code:
Ignition on.
OBD: Apps | Soundaktor | Value: Off - 100%
- One more still to do - enable the RS3 style G-Meter for the virtual cockpit so it can be available and selectable in the Sport Layout.
Code:
Ignition on (maybe bonnet open?)
OBD: Control Units | Dashboard | Long Coding | Acceleration Display | Yes
