I was in neutral foot on brake and clutchWere you sat with your foot on the break at the time? If so it's just telling you to put it in neutral rather than sit there in 1st.
I've got parking plus but the display is small and on the right side of the MMIThe virtual parking display operates only where you have spec'd parking plus. Do you have front parking sensors? If not, you don't have parking plus.
If you put handbrake on and come off clutch the arrow next to neutral will drop off, it's just suggesting you go fully into neutral, same as when the arrows appear to shift down or up.I was in neutral foot on brake and clutch
Pop it in neutral, lift off the clutch and the stop/start will operate.
That's the full extent of the visual parking display, it doesn't go full screen.It has a '+' symbol which I thought would enlarge the display but it doesn't do anything
