Squirrelofdoom
Hi guys,
Got a problem with the S3 at the moment where if I leave it to sit overnight, it will need cranking up to 10 times before it eventually fires.
I was thinking massive boost leak perhaps, maybe in the fuel vac lines, but then I saw somewhere else in a thread something about a one way valve that stops fuel flowing away from the engine after the engine is turned off.
It definitely feels like there is no fuel getting to the engine, and then as I continue to crank it slowly but surely gets there and then eventually has enough fuel to fire. I've left the car sat now as I don't want to cold crank it. I recently had the fuel pump changed, so wonder if something went wrong during the change.
Anyone know about this one-way valve?
