  2. Dismiss Notice
Engine oil for s3
Trev241 Jul 28, 2020
  1. Trev241
    Trev241 Member
    268
    22
    Just had the S3 serviced at local dealer and as usual specified fully synthetic oil.
    Just looked at the invoice oil used as follows =
    VGS 555 02M2E UR SPECIAL G 5W-40.
    Never heard of such a thing so can anyone tell me what sort of junk this is ?
  2. Avatar
    snack-media
    Advertisement
  3. Gazwould
    Gazwould Well-Known Member
    7,447
    3,023
    Vasoline Grease Supplied Ur Special..
    Hmmmm..
    JohnM100 likes this.
  4. pburv
    pburv Well-Known Member
    5,956
    11,894
    Local 'chippy' uses it..:stupid:
    Peter82 likes this.
  5. pburv
    5,956
    11,894
  6. rafletcher
    rafletcher Active Member
    280
    71
    Yebbut its 502 / 505 spec, and those, as has been noted elsewhere on this forum recently, older VAG specs. Current specs are 504 / 507.
  7. Gazwould
    7,447
    3,023
    Probably 502.00 505.01 spec 5W40 .
    A medium quality oil whereas you should of received high .
  8. Trev241
    Trev241 Member
    268
    22
    Yep found out it's VW own brand 502.00 505.01 looks like they will have to change it.
    Gazwould likes this.
  9. CanadaA3wales
    CanadaA3wales Canadian living in South Wales - Audi A3 8V 150BHP
    295
    70
    This is the stuff they used:
    https://www.autodoc.co.uk/vag/13562467
    Not the newest oil, I would demand 504 oil especially when they charge well over £100.00 for a simple oil change.
    You can get top quality mobil 1 at ATS for 80.00 but Audi charge 150.00 for oil that has not been used in years.
  10. ST200
    ST200 VAG Convert
    116
    147
    43
  11. Trev241
    Trev241 Member
    268
    22
    They did not use Quantum the description is as posted and they think its made by Shell hard work trying to find out what's in my car.
  12. Avatar
    snack-media
    Advertisement
  13. CanadaA3wales
    295
    70
    I already advised what was in your car.
    If you type the spec into google then this oil comes up, its VW own oil, obviously not sure the actual make of oil as the barrels are labelled VW on the bottles. Maybe they are castrol or maybe quantum, who knows
    Type the oil code on your invoice and the link I sent if correct.
