Where can I buy new engine mount bolts from? I'll be changing the left, right and lower dogbone mount next week but haven't a clue where to get new bolts.
If your mounts are new expect a bit of vibration and noise at first, will settle down after putting some miles on them, got THS mounts and Superpro dogbone on my car makes a noticeable difference to the way your power is put down.
I've heard that to be the case, may have to plan a long drive on Sunday to bed them in. The left/right mounts are from a 1000mile braker so they should have bedded in a little. As for the dogbone I am only changing the rear bush this weekend. did you change the front bush aswell?
