Efficiency can disengage the clutches on DSG enabling you to coast/freewheel down hills, and also control the air conditioning compressor to disengage if free cooling is available.
I have to admit that so far I've found dynamic a bit frustrating.
30mph = the car drives around in 3rd - 4th gear at 3000+ RPM
60mph = car drives around in 5th.
Manually change up as I'm either going down hill or cruising & a couple of seconds later it overrides me & changes down again.
It's like there's some setting where the revs are not allowed to drop below 3000RPM...
Stay in Dynamic mode but push the gearstick into D instead of S?
Really? Isn't that coasting in neutral? That's considered bad practice as you are not fully in control of the car and can't rely on engine braking to assist the brakes - disengaging the clutch in any gear Without changing up or down on a driving test is an instant fail. Can't see a manufacturer introducing a system that ignores that fact. Any auto transmission that slips the clutch or disengages the clutch at speed for longer than a change up/down would be considered operating under dangerous fault by the DVSA.
More likely the ECU senses the gradient is assisting from the amount of fuel injected / engine speed / wheel speed and adjusts the throttle response to reduce injection - coasting in gear by minimising the fuel delivery irrespective of throttle position. Making your right foot lighter on the downhill if you like. And legal too.
Yes. I ruled out Dynamic until I thought of that (Dynamic defaults to S mode in the gearbox).Stay in Dynamic mode but push the gearstick into D instead of S?
Yes, and stays in gear if you are braking (the few times I've tried it)....I'm pretty sure when you're on efficiency mode and the clutch has been disengaged, as soon as you touch the brake or the accelerator the engine will increase the revs back to normal so you have full engine braking.
