I was wondering if opening the exhaust flaps would infact reduce fuel economy ?
^ Sorry, should have made clear I was replying more about the power part of the question, rather than the mpg
how do you keep the flaps open?
i wouldn't say its given me more power.
just more responsive, the only reason i say this is because i didn't tell the mrs what i did and we went out to which half way through our journey she said "it seems more responsive lower down, what have you done?"
now if a passenger picks it up, you need to take it on bored.
Normally, when boy racers fit big bore exhausts, it results in less power, not more (wrong gas flow velocity)
Interesting discussion.
I have a fuel tracker S/S that I've always done not out of monetary interests but to see the effect of mods. For example mpg went down 0.5mpg after the remap and another 0.5mpg after I'd hit 10k miles so fully loosened up I guess but then it dropped 1.5mpg after adding the cold air intake and turbo inlet pipe. I'll disconnect my valves and run it like that for 2 tanks and see what happens.
so where do you stand on decat pipes?...
opening the valves is different to fitting a cherry bomb to a 12XE...
Normally - subjective and personal. potato potata.
i am just shy of 10k, maybe now its loosened up nicely, this has had the positive effect on my MPG?
now lets argue that your mpg went down after the map and CAI because you like the noise / extra power, so you are heavier on the right foot?
.......by then i should also have my DTUK fitted - i was going to order it today actually but I'm still debating it an managing to talk myself out of it. fml.
LOL quite possibly mate certainly after having the map put on but my driving habits after fitting the CAI have changed less so.
Good timing for the box I think DTUK have just launched a new 3 channel system ?
Tri-channel MultimapPlug & Play Diesel Performance System from DTUK is available for a selection of new Common Rail diesel engines
new 3 channel system - i will look into this, i haven't heard of this?
The JB1 box is alleged to look at more than just boost (also tweaks fueling) - but I've not seen any hard evidence of this yet.
I think AP Automotive are doing the UK distribution for the JB1.
http://www.apautomotive.com/blog/2016/03/burger-motorsport-at-ap-automotive
I'm probably selling my DTUK box in the very near future, if anyone wants one (with the latest v3 software on it)
What mpgs on average are you guys seeing on the motorway ? I'm seeing around 29-30mpg at around 75-80 although my cars only covered a 1000 miles. I read an article a few days ago about the cjxc engine and how it's engineered to have some back pressure to allow the turbo to spool quicker so surely the exhaust flaps may have some effect ? I do like the better sound but I'm considering closing them as I have just secured a job at rolls-Royce so will have to commute 60 odd miles a day
I've opened them using VCDS as soon as I collected the car haha, so I don't even know how the car is with them closed. I'll try it out on a few runs and I'll see if there's a difference.there is plenty of back pressure in the downpipe, have you seen the shape of it and how close the CAT is to the turbo?
the valves is not going to cause any issues that i can see, taking the downpipe into consideration, IMO.
as for the milage, well, yours will get better in time, don't worry about that. Engines in general perform better when the miles have been added, 1k miles is still VERY early days.
Although, i get around 25-28 on a good run, but I'm not the slowest of drivers.
as for closing your valves, i assume you haven't disconnected them or opened them on VCDS?
if you place it in comfort, they will stay closed. in Dynamic, its based on RPM and throttle %. under 4k it'll be closed.
So I take it if you disconnect the valves by hand whist on your drive, once you pull away they must open and just stay open? Or are the open once ignition it off?
Does doing this log faults in the ecu??(worried about warranty etc)Ignition off, the valves are open.
Disconnect
Start up and they will stay open.
Connected
Start up and they close.
