Hello All!
I've had a problem with my passenger wing mirror for the last couple of years, but its just caused it to fail the MOT. Had it investigated but the garage can't find the cause. The main issue is that the indicator doesn't work.
Plugged a new unit in but still didn't work. Not sure how long the indicator hasn't worked, certainly passed the MOT last year, so not sure why it's an issue now.
The mirror will also not dip on the switch, tried two new switches. The mirror folds and if I remember correctly from the last time we had frost, it also heats.
Had it into my normal mechanic recently and they ran loads of tests but got nowhere. They say that when hooked unto the computer and they use the switch, it is seeing the message on, then when the send a message to the mirror, it responds correctly. I assume it was all done in VCDS monitoring etc.
I'm taking it back to the normal garage in the morning for another go, but none of us are optimistic at the moment, anyone seen anything like this before?
Any suggestions? Worried I'm just going to have to PX it before the old MOT expires.
help...
help...
