DAB Radio reception
Markjb
A couple of months ago I retrofitted a DAB radio unit to my Avant, using the OEM aerial in the osr window and the DAB aerial amplifier.
So far I have to say I'm disappointed as the DAB reception keeps dropping out.
Does anyone know if there is a way of testing aerial strength at all?
TIA
Simon968
I did that same with my Avant and my DAB reception isn't perfect, but it is better than with the stick on aerial that I had in my Passat CC.
If there is a way of checking the signal strength, I'd be interested too.
rich dj
2015 A4 Avant 2.0TDI SE Quattro 190 Technik
Hi you can set the dab signal strength on the main screen if you can get to the "secret menu" this has to be enabled by vag-com VCDs.
Simon968
Thanks for the info.
Do you mean that you can set the MMI to display the signal strength or that you can adjust the amount of signal boosting that the amplifier gives?
rich dj
On the display it shows from 1 to 7.
Give me 2 mins I will take a picture
rich dj
rich dj
The number 7 beside the Bluetooth symbols
Is the signal strength
rich dj
Also some USB converters for charging your phones wipe out the dab signal too. Worth noting.
B5NUT
Well-Known Member
There are lots of devices that wipe out DAB signals, dash cams etc. Unfortunately there is a lot of equipment that is being sold on ebay & amazon that don't have valid UL/CE EMC testing and that equipment can have a massive impact on your DAB signal.
Markjb
So, still disappointed with my DAB reception and have now bought my own VCDS cable and can keep closer eye on my car generally.
Definitely not down to the USB cigarette plugs I have as it makes no difference if they are in / on at all. They weren't bought on ebay either.
However, the following error comes up from time to time which I'm assuming must either be down to the connections (which appear ok) or maybe a kink in the cable somewhere, causing the open circuit fault:
1 Fault Found:
02877 - Digital Radio Antenna (R183)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 111855 km
Time Indication: 0
Date: 2016.11.28
Time: 11:42:08
Freeze Frame:
Voltage: 11.90 V
Does anyone have any idea?
Thanks in advance
Mark
swampdonkeygj
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 112
Mileage: 111855 km
Time Indication: 0
Date: 2016.11.28
Time: 11:42:08
Freeze Frame:
Voltage: 11.90 V
Thanks in advance
Mark
I have similar so would be interested to know if you get anywhere with it.
opronnie
my allroad 2008 mmi does not allow me to press the 2 buttons to access the green mene...any advice as to how i can get this sorted? cheers.
