I've just bought a CTEK MXS 5.0 to help maintain the battery during winter (lots of short journeys with high elec demand). I'm going to fit the permanent direct connector to make it all a bit neater and wondered if anyone else has done so on a B7 (Tfsi). If so, what did y'all do about the neg side of things?
CTEK's literature and currently held opinion seems to be NOT to go direct the the battery negative clamp. But I'm not sure that this is actually a problem. Obviously I'm aware of the hydrogen+spark risk on connect/disconnect, but surely this is negated when using the CTEK 'Comfort Connect' fittings anyway.
I'm also aware that if there's a battery monitoring system fitted via the main vehicle earth lead, you would effectively bypass it by connecting direct to the battery, but AFAIK the B7 wasn't fitted with one.
Besides that, the only other thing I can think is the risk of a voltage spike damaging things (which may be damped out by earthing further from source?), but isn't that a throwback to the analogue and VERY early electronic systems of yesteryear?
Very happy to be corrected on any of the above, and also interested what points other people have used for their negative connections in this application.
Any thoughts chaps & chappesses.......?
