yes i think mine did, drove me mad, it was awkward to find see for a start what was causing it, finally i removed the front shocker assembly with upper arms attached and from what i can remember one of the two top control arm bushes had slightly moved as though it was being pushed out and was catching aginst the top mount assembly causing the creak, i replaced both top control arms both sides of the car and the creak was gone, joy!!!, what made it more of a job was the top pinch bolt seized, i thought it was this causing the creaking but it wasnt, was a bit of a job to drill out and if you do have to revert to this take your time, drill straight and use sharp drills drilling slowly and lubricate with some oil, last thing you want is the drill breaking, , i did not use the expensive oe pinch bolt (£13) or more but used a imperial size equivilant, cant quite remember the actual size offhand but have a spare in the shed what i can measure for you if need be, used these replacement bolts on my b5 and b6 with no problems, let me know if you need the size and il measure, cheers, andy
