Hello I have had a search but everything I've done doesn't work.
First off the headlight washers, I have checked the fuse's and pulled out the washers to make sure they slide freely but still they don't work. So unless the motor has packed up?
Second the headlight auto levelling. When I fire the car car up the headlights are at a 'normal' height but as soon as I start driving the drivers side drops to where you can't see the road in front of you! I have manually adjusted it but still doesn't work. Will the auto levelling sensor be broken or need adjusting? as the rear one has been off as the Tie arms have been replaced a few months ago.
Many thanks
Many thanks
