Since my rod fitting/engine build, i have the red coolant light on the dis with three beeps everytime i turn the ignition on, hot or cold... I didnt have this problem before. Now the only thing ive changed in relation to the cooling system is the header tank because mine was all yellow... Now i have vcds so i checked engine module and instruments for faults and all clear so i messaged the seller telling him i think its the header tank and got this reply...
Hello - the sensor is connected to the brain so if it is faulty you will get a fault code, I suspect it is something else wrong as the sensor will either give a reading or not and if it doesn't you will get a fault code, I can also confirm we have never had any of these faulty.
Any shed of truth to this or ********?
