- Joined
- Oct 28, 2014
- Messages
- 290
- Reaction score
- 93
- Points
- 28
is there common oil leaks? I’ve cleaned the engine then checked, looked to be coming from the oil filter housing to block gasket, replaced the gasket that was also smeared with gasket goo so I thought it was promising.
Set the injector back lash so replaced the rocker cover gasket too, back of the head looks dry including the tandem pump area, it looks dry by the oil filter housing now but I still have a leak by the looks of it.
Are rear main seals common?
Thanks.
Thanks.
