metzer_001
Hi,
So yesterday after work my car failed to start, I'm pretty sure its the battery as the MMI gave a low battery warning a few weeks ago. I left the car for 15 mins before trying again and the car started. The battery level meter on the MMI did show around 20-30% however accurate that reading may be. My cars a 2011 S5, and I assume is running on the same battery from new.
Regarding a new battery, I've read conflicting reports on whether the battery needs coding via VAG-COM upon changing. ( https://www.audiforums.com/forum/b8-models-72/audi-a4-b8-battery-coding-176172/)
Has anyone got first hand experience of replacing the battery? Must it be coded via VAG COM or can I simply skip that step. A local Audi specialist quoted me 250£ fitted, using the OEM battery. A quick look at Halfords brings up a price of £130 plus £15 for fitting. However I doubt Halfords would code the battery (if it does need coding).
I didn't even realise that the battery in these cars is under the spare wheel in the boot, I wonder if I could use jump leads to start if need be? It looked as though I would have the undo the metal top cover of the battery to get to the +/- ends.
Edit - car started fine this morning, I'm trying to not use any heating / radio etc to conserve battery whilst I get this sorted.
Second Edit - If it did need coding, would only the OEM battery work with the car? I.e Could I code a third party branded battery?
Cheers folks
Cheers folks
