- Joined
- Oct 2, 2015
- Messages
- 3,565
- Reaction score
- 770
- Points
- 113
Hi,
So I have had a thought about my issue regarding getting 0.95 lamfa even though the load is going past 200% and throttle plate is 100% and I have raised a similar thing before - PEDAL POSITION
for me to have such a poor enrichment at this means the car's desired torque is around 70% if I look at my mapping the pedal position of "half throttle" (which isn't really half throttle in a fly-by-wire it is 50-60% pedal position - I think the car decides the throttle position, load etc based on the entire map - not the pedal)
so I often drive using the throttle pedal and when the power comes in I wont carry on pressing down. This table shows a 60% pedal position sets the desired torque to about 70% which at 5500rpm is only 0.95 lamfa which is too lean.
I think this creates "desired torque %" which isn't necessarily "actual torque %" but the "desired torque %" is used as the driving attribute to determine lamfa rather than actual torque.
I have set this to try and compensate - but I think it is solved by pressing the pedal to 100%
there are.. "sort of" complaints about the use of "desired torque" on s4wiki
in all honesty after 35 years of trying to drive / ride efficiently by only just using the throttle - sometimes you need to press / twist the throttle 100% down/round to go fast, not half down/round to go fast(ish) and save a little fuel.
