Had 2 strange gear changes happen this morning on my way into work. They weren't very smooth, a bit clunky, then the EPC light came on. After that the gear changes were fine for the rest of my journey. I did a quick check and got the following codes (below). Are they related? Could the Camshaft position sensor also relate to the strange noise I get when I start the engine from cold that has been happening for the last week? Seems to be a bit more of a grumble from the engine.
All help greatly appreciated.
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 8E1 910 559 HW: 8E0 907 559 H
Component: 3.2l V6 FSI 0040
Revision: --H19--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0018
Shop #: WSC 06325 000 00000
VCID:
2 Faults Found:
000832 - Camshaft Position Sensor (G40)
P0340 - 006 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 4
Mileage: 155881 km
Time Indication: 0
Freeze Frame:
RPM: 1792 /min
Mass Air / Rev.: 119.9 mg/str
Temperature: 18.0°C
Idle
Bin. Bits: 00000100
Speed: 0.0 km/h
001796 - Clutch Switch (F36)
P0704 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 157544 km
Time Indication: 0
Freeze Frame:
RPM: 2816 /min
Mass Air / Rev.: 299.8 mg/str
Temperature: 87.0°C
Part Throttle
Load: 44.3 %
Speed: 117.0 km/h
Readiness: 0000 0000
VCID:
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 4
Mileage: 155881 km
Time Indication: 0
Freeze Frame:
RPM: 1792 /min
Temperature: 18.0°C
Idle
Bin. Bits: 00000100
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 157544 km
Time Indication: 0
Freeze Frame:
RPM: 2816 /min
Temperature: 87.0°C
Part Throttle
Load: 44.3 %
Speed: 117.0 km/h
