hope maybe someone can help me out..
I've searched quite a bit and really can't find much info
My car a Audi S3 8l AMK
I have the correct VCDS and played around with it ALOT (coding etc)still no hope
Also no fault codes at all
Checked all fuses and everything seems okay
So my problem is this.
Problem 1
When I lock the car the small red LEDs on the door panels don't flicker and I don't get that BEEP sound..if I'm sitting in the car and lock the car no matter what movement I do the alarm won't go off even if I press that small button on the lower rear back panel, but as soon as I put the key onto the ignition the alarm goes off...
Problem 2
Also notice that the lights on the lower part of the door panels don't come on when I open the door, on both sides. I've checked the bulds and fuses and all is 100s
Then my last problem is global closing the Windows don't close with the remote
Sorry for the long write up but maybe someone can guide me in the right direction..thank guys
This reminds me I need to update my rides threads
Problem 1
Problem 2
