Hi all,
Earlier my A3 would not start. You'd turn the key but it would be really stiff and not start the engine. The MMI would come up a little bit before disappearing back into the dash. After five minutes this solved itself (like the other three times it has happened) and I drove away!
Now I'm at a services... The car's handbrake will not engage when the car is in neutral. As soon as you lift up on the clutch the handbrake turns off The only way around it is to put the handbrake on, go into neural, turn the car off and then release the clutch. This hasn't happened before but it seems like releasing the clutch is causing a power surge in the engine.
Nightmare!
Steven
Nightmare!
Steven
