Hi All,
I have recently developed an intermittent ABS and/or Traction control light on the dashboard. They will be on for a day or two, then go off until I hit a bump in the road when they come back on.
The only area I've been working in recently is around the headlights when I replaced a couple of bulbs, so I'm wondering if I have caused a loose connection on a sensor for the ABS or Traction control system.
Are there any sensors for these systems located near the headlights or behind the front grille? Or any that have wiring that routes behind the headlights?
If I can't suss it soon, I probably end up buying a pukka VCDS set-up, as my eBay lead now refuses to play ball.
Cheers,
Cheers,
