- Joined
- May 3, 2017
- Messages
- 55
- Reaction score
- 13
- Points
- 8
Hi,
Intermittent ABS & ESP Light Illuminated, any ideas what the cause is - VAG.com scan below:
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan:
01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,
76
Address 01
Controller: 038 906 019 FP
Component: 1,9l R4 EDC 0000SG 1467
Coding: 00002
Shop #: WSC 63351
WAUZZZ8E52A066247 AUZ6Z0A0155075
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open
or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: N/A
Address 03
Controller: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04255
Shop #: WSC 00182
2 Faults Found:
01826 - Sensor for Steering Angle (G85): Supply
Voltage Terminal 30
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
30-10 - Open or Short to B+ -
Intermittent
Address 08
Controller: 8E0 820 043
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
No fault code found.
Address 09
Controller: 8E0 907 279
Component: int. Lastmodul RDW 0510
Coding: 00001
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 16
Controller: 8E0 953 549 F
Component: Lenksáulenmodul 0304
Coding: 00001
Shop #: WSC 63351
Address 17
Controller: 8E0 920 950 F
Component: KOMBI+WEGFAHRS. RB4 D21
Coding: 00400
Shop #: WSC 00001
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
Intermittent
01304 - Radio
49-00 - No Communications
Address 45
Controller: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft
alarm System
43-00 - Closed
Address 46
Controller: 8E0 959 433 AJ
Component: Komfortgerát T9F 0617
Coding: 06859
Shop #: WSC 63351
10 Faults Found:
01134 - Alarm Horn (H12)
29-00 - Short to Ground
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment
Switch
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01561 - Left Rear Door
59-00 - Can't Unlock
61-00 - Won't De-Safe
01562 - Right Rear Door
01559 - Drivers Door
End
Scan:
76
Address 01
Coding: 00002
Shop #: WSC 63351
1 Fault Found:
or Short to Plus
Readiness: N/A
Address 03
Coding: 04255
Shop #: WSC 00182
2 Faults Found:
Voltage Terminal 30
Intermittent
Address 08
Coding: 00000
Shop #: WSC 63351
Address 09
Coding: 00001
Shop #: WSC 63351
Address 16
Coding: 00001
Shop #: WSC 63351
Address 17
Coding: 00400
Shop #: WSC 00001
2 Faults Found:
Intermittent
01304 - Radio
Address 45
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
alarm System
43-00 - Closed
Address 46
Coding: 06859
Shop #: WSC 63351
10 Faults Found:
35-00 - -
35-00 - -
Switch
35-00 - -
35-00 - -
End
