A4 08 2.0 TDI - Fault Codes
Adill
  1. Good evening,
    A fellow member here kindly just scanned my car and was presented with the following codes. Can anyone shed some light please from experience
    7 Faults Found:
    5211 - Fuel Rail/System Pressure
    P0087 00 [101] - Too Low
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 170972 km
    Date: 2017.06.27
    Time: 18:01:08
    Engine speed: 3128.50 /min
    Normed load value: 99.6 %
    Vehicle speed: 47 km/h
    Coolant temperature: 34 °C
    Intake air temperature: 18 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 14.140 V
    Unlearning counter according OBD: 80
    Crankshaft speed (RPM): 3128.5 /min
    Vehicle speed: 46.68 km/h
    Mean injection quantity: 54.32 mg/stroke
    Fuel temperature: 22.9 °C
    Fuel high pressure: actual: 997400 hPa
    Rail pressure regulation: status-Bit 0: 00000101
    Inj Crv st Inj Char Act Val 0-Bit 0: 00111000
    5213 - Fuel Rail/System Pressure
    P0088 00 [101] - Too High
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 170911 km
    Date: 2017.06.26
    Time: 18:40:33
    Engine speed: 1361.00 /min
    Normed load value: 55.3 %
    Vehicle speed: 57 km/h
    Coolant temperature: 82 °C
    Intake air temperature: 25 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 14.020 V
    Unlearning counter according OBD: 79
    Crankshaft speed (RPM): 1361.0 /min
    Vehicle speed: 57.95 km/h
    Mean injection quantity: 20.04 mg/stroke
    Fuel temperature: 39.6 °C
    Fuel high pressure: actual: 1.4594e+006 hPa
    Inj Crv st Inj Char Act Val 0-Bit 0: 00011000
    5456 - Starter Will Not Turn
    P3054 00 [096] - Jammed or Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    5253 - Diesel Particle Filter; Differential Pressure Sensor
    P2452 00 [175] - Elect. Malfunction
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 165949 km
    Date: 2017.03.17
    Time: 09:36:55
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 47 °C
    Intake air temperature: 23 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 13.660 V
    Unlearning counter according OBD: 40
    Crankshaft speed (RPM): 0.0 /min
    Vehicle speed: 0.00 km/h
    Vehicle voltage terminal 30: 13660 mV
    Particle filter: difference pressure: 0 hPa
    Particle filter: offset for differential press.: 47 hPa
    Exhaust gas vol.flow particulate filter: 0.0 m³/h
    Intake air temperature: 23.2 °C
    4985 - Cylinder 2 Glow Plug Circuit (Q11)
    P0672 00 [096] - Electrical Fault
    4986 - Cylinder 3 Glow Plug Circuit (Q12)
    P0673 00 [109] - Electrical Fault
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 165949 km
    Date: 2017.03.17
    Time: 15:22:39
    Engine speed: 880.50 /min
    Normed load value: 38.4 %
    Coolant temperature: 12 °C
    Intake air temperature: 9 °C
    Voltage terminal 30: 11.200 V
    Crankshaft speed (RPM): 880.5 /min
    Vehicle voltage terminal 30: 11200 mV
    Coolant temperature: 12.9 °C
    Glow status-Bit 0: 00000000
    Glow status-Bit 8: 00000000
    Preheat time: 1600 ms
    Fuel temperature: 10.5 °C
    5174 - Fuel Pressure Regulation
    P1065 00 [109] - Regulation Discrepancy
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 25
    Mileage: 170908 km
    Date: 2017.06.16
    Time: 13:22:04
    Engine speed: 1820.00 /min
    Normed load value: 59.2 %
    Coolant temperature: 17 °C
    Intake air temperature: 20 °C
    Ambient air pressure: 1020 mbar
    Voltage terminal 30: 12.580 V
    Crankshaft speed (RPM): 1820.0 /min
    Vehicle voltage terminal 30: 12580 mV
    Fuel high pressure: actual: 970600 hPa
    Mean injection quantity: 20.12 mg/stroke
    Fuel Metering Valve: 21.83 %
    Fuel Pressure Regulator Valve: 21.93 %
    Readiness: 1 1 0 0 0
Did you clear them then go for run and scan again to see what comes back. Some of them are few months old and might not actually be a fault after clearing them and rescanning.
