Leaking caliper
zeeeebo
Lifes one big laugh
worthing
Ok so a month ago my flexible hosing burst and I got the garage to mend it costing 77 quid. Then my brakes started leaking again so tool it back and they said it was a corroded brake line bolt and had to sand the caliper down and refit with new bolt , this cost another 151 quid which I was not happy about! My brakes now feel really soft and spoungy, why is this? Are they ok
you must have air in the system they should have blead the brakes getting all the air out, you should take it back and get them to finish the job (bleed the system)
This is what I thought but they aren't as bad as un bled brakes
it could be your brake master cylinder if your flexi burst and you have been using your brakes you could have flipped a seal dont think you can get repair kits anymore so you will have to replace it...................................hope this helps.
they are still working fine just feel a bit softer than usual. just went for a brakey drive and are now feelin a bit better
7K
10
772
29
4K
