EVAP system- small leak detected
kgates
6 in the box
Houston
Not sure were to begine with the EVAP code, i checked the obvious the fuel cap. Any other ideas?
Thank you in advance.
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUNF78P66A002043 Mileage: 85310km/53009miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 B HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0080
Revision: --H10--- Serial number: AUX7Z0E2FNH04O
Coding: 0103010A18070160
Shop #: WSC 25101 444 52946
5 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 84868 km
Time Indication: 0
Date: 2008.12.28
Time: 09:05:42
Freeze Frame:
RPM: 1190 /min
Load: 37.6 %
Speed: 1.0 km/h
Temperature: 14.0°C
Temperature: 14.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.478 V
000770 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 84868 km
Time Indication: 0
Date: 2008.12.28
Time: 09:05:53
Freeze Frame:
RPM: 1229 /min
Load: 42.7 %
Speed: 0.0 km/h
Temperature: 7.0°C
Temperature: 9.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.605 V
000771 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84868 km
Time Indication: 0
Date: 2008.12.28
Time: 09:06:02
Freeze Frame:
RPM: 1188 /min
Load: 37.2 %
Speed: 0.0 km/h
Temperature: 10.0°C
Temperature: 9.0°C
Voltage: 14.605 V
000772 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 84869 km
Time Indication: 0
Date: 2008.12.30
Time: 10:50:17
Freeze Frame:
RPM: 1201 /min
Load: 46.3 %
Speed: 9.0 km/h
Temperature: 24.0°C
Temperature: 15.0°C
Voltage: 14.605 V
001110 - EVAP System: Very Small Leak Detected
P0456 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 84908 km
Time Indication: 0
Date: 2009.01.12
Time: 13:25:46
Freeze Frame:
RPM: 2603 /min
Load: 55.7 %
Speed: 70.0 km/h
Temperature: 51.0°C
Temperature: 10.0°C
Voltage: 14.605 V
Have the same code on my 2008 Audi A3.....did you find a solution. Was thinking of changing the Evap purge valve.
